https://help.tallysolutions.com/docs/te9rel61/Tax_India/VAT/andhra_pradesh/AP_Pur_Ret.htm
Purchase Return (Andhra Pradesh)
Record purchase returns in debit notes for taxable goods. Specify the VAT rate in Company Details screen.
To create a debit note for taxable goods whose VAT rate is specified in Company VAT Details screen of F3: Statutory & Taxation features
1.    Go to Gateway of Tally > Accounting Vouchers > Ctrl +F9 (Debit Note).
2.    Enter the Original Invoice No. and Date of the purchase invoice against which the debit note is recorded.
3.    Select the required party name from the List of Ledger Accounts.
5.    Select the common purchase ledger.
6.    Select the required taxable stock items.
7.    Enter the Quantity and Rate. The amount is automatically displayed in the Amount field.
8.    Select the required common VAT ledger.
9.    Set the option Provide VAT Details? to Yes. The Statutory Details screen appears.
Note: In case of purchase price rise, when a credit note is recorded in voucher mode to debit a purchase ledger, the option Change in Consideration appears.
10.  Select the required Nature of Return and press Enter. The debit note appears as shown below:
11.  Press Enter to save.
