https://help.tallysolutions.com/docs/te9rel61/Advanced_Features/Advanced_Inventory_Features/Displaying_POS_Register.htm
Displaying POS Register
POS Register lists all transactions made over a particular day and by default displays the last invoice entry date of a POS invoice. Each POS Invoice is further drilled down to obtain the lowest level of information.
To view the POS Register
1.    Go to Gateway of Tally > Display > Accounts Books > POS Register. The POS Register appears as shown below:
Note: The POS Register will be available, only if the option Use for POS Invoicing is enabled in Voucher Type and at least one entry is made.
2.    Click F1: Detailed to view the report in detailed mode.  The POS Register appears as shown below:
3.    Click F12: Configure to configure the report.
4.    Set Show Inventory Details also to Yes and view the List of All POS Vouchers with Inventory details.
Alt+F12: Range Filter
You can filter POS invoices based on a range of parameters such as party name, buyers name, cost centre, cost category and son on as shown below:
