Purchase from Unregistered Dealer (Goa)
https://help.tallysolutions.com/docs/te9rel61/Tax_India/VAT/Goa/GA_Pur_from_URD.htm
This topic explains the procedure to record purchase transaction from unregistered dealer.
To record a purchase transaction from URDs
2.    Click F12: Configure and enable the relevant option.
3.    Enter the Supplier Invoice No. and Date if any.
4.    Select the party ledger in Party's A/c Name option.
5.    Select a common purchase ledger in which the option Is VAT/CST Applicable is set to Applicable, and Set/Alter VAT Details is disabled.
o     Select Purchase From Unregistered Dealer as Classification / Nature in the VAT Classifications Details screen.
o     Press Enter to save.
6.    Select the required stock item. Enter Quantity and Rate. The purchase invoice appears as shown below:
7.    Press O to consider the nature of transaction selected in the invoice and save.
