https://help.tallysolutions.com/docs/te9rel61/Tax_India/VAT/Maharashtra/MH_jv_decrease_input_tax.htm
Decreasing Input Tax (Maharashtra)
In Tally.ERP 9, you can record a journal voucher to account for the decrease of input tax.
To create journal voucher for CST adjustment
2.    Click J: Stat Adjustment to enable required options in Stat Adjustment Details screen.
o     Select the option VAT in the Type of duty/tax field.
o     Select the option Decrease of Input Tax in the Nature of adjustment field. The Stat Adjustment Details screen appears as shown below:
o     Press Enter to save and return to voucher screen.
3.    Debit the CST ledger created under the group Duties & Taxes.
o     Enter the Rate, and Assessable Value in the VAT Details screen.
5.    Credit the input VAT ledger.
6.    Press Enter to save.
