https://help.tallysolutions.com/docs/te9rel61/Tax_India/VAT/Madhya_Pradesh/MP_Interstate_Pur.htm
Interstate Purchases (Madhya Pradesh)
Interstate purchases can be against Form C and with multiple CST rates. These can be recorded in the corresponding invoices.
Interstate purchases at 0% against Form C
Interstate purchases have to be taxed at 0% CST rate against Form C when:
●     It is transit transaction against Form E2.
●     The goods are taxed at 0% under section 8(5) of CST Act read with section 8(4) (against Form C).
To record such purchases, the following enhancements are introduced:
●     Nature of transaction - Interstate Purchase Exempt - With Form C is provided.
●     The option Is under CST exemption is provided. After selecting the Form to issue as Form C, you can set this option to:
o     Yes, if the goods are taxed at 0% when purchased against Form C. In the Form 10 report, the text Under exemption appears when this option is set to Yes.
o     No, if the transaction is against Form E1/E2.  In the Form 10 report, the text Subsequent of E1/E2 appears when this option is set to No.
To record an interstate purchase invoice at 0% against Form C
2.    Enter Supplier Invoice No. and Date.
4.    Set the option Is Against C Form? to Yes in Party Details screen. This option appears only when the State selected is other than Madhya Pradesh.
5.    Select the purchase ledger predefined with the nature of transaction Interstate Purchase Exempt - With Form C.
6.    Select the required stock items.
7.    Set the option Provide VAT Details? to Yes. In the Statutory Details screen,
o     Enter the Builty/RR No. and date.
o     Select C Form as the Form to issue.
o     Set the option Is Under CST exemption to Yes/No as required.
o     Press Enter to save and return to purchase invoice.
8.    Press Enter to save.
Interstate Purchase Against Form C
To record an interstate purchase invoice against Form C
5.    Select a common purchase ledger in which the option Is VAT/CST Applicable? is set to Applicable, and Set/Alter VAT Details? is not enabled.
Note: If the option Is Against C Form? is set to Yes in Party Details screen, the tax gets calculated at 2% CST rate. This is irrespective of the tax rates defined in the inventory or accounting masters.
7.    Select the CST ledger grouped under Purchase Accounts or Direct Expenses with the option Type of duty/tax set to CST.
8.    Set the option Provide VAT Details? to Yes.
o     Enter the C Form details in Statutory Details screen as shown below:
9.    Enter Narration, if required.
10.  Press Enter to save.
Interstate Purchase at Multiple CST Rates
To record an interstate purchase invoice for items attracting multiple CST rates
6.    Select the required stock items whose VAT rates are specified either at the stock group or at the stock item level. Enter Quantity and Rate for each stock item.
8.    Click A: Tax Analysis to view the Tax Analysis screen.
o     Click F1: Detailed to view in detailed mode. The Tax Analysis screen appears as shown below:
o     Press Esc to return to purchase invoice.
