                                    It is not necessary to record an adjustment entry to adjust output VAT with input VAT amount whenever VAT is payable, because the VAT amount is auto adjusted from release 5.0 onwards.
'Is an adjustment entry required for balancing the output VAT with the input VAT amount?' has been shared with
