Filing revised return for the previous financial year
https://help.tallysolutions.com/docs/te9rel61/Tax_India/VAT/Maharashtra/MH_Revised_Return_for_Previous_FY.htm
The new e-filing template is effective from 1st April 2016. Returns for previous financial year have to be filed using the old format, which can be generated using an earlier release of Tally.ERP 9.
