You can easily print ledger vouchers in Tally.ERP 9 by using the ledger option from the Account Books.
To print Ledger Vouchers report
1. Go to Gateway of Tally > Display > Account Books > Ledger.
2. Select the required Ledger. The Ledger Vouchers screen appears.
3. Press Alt + P to print Ledger Vouchers, the printing configuration screen appears.
4. Configure the required options in the Print Report screen.
5. Press Enter to accept the screen and print the Ledger Vouchers report for the selected ledger.
'Printing Ledger Vouchers' has been shared with
