You can synchronise data on-demand or online using the Tally.NET Server or Private Network (IP address). A valid TSS is required to synchronise data using Tally.NET Server, for both online and on-demand options.
To synchronise data
1. Configure Server and Client Companies.
2. Configure TSS feature on the Server Company and Client Company.
3. Connect Server Company to Tally.NET Server.
4. Create Sync Rule on Client Company.
5. Activate Sync Rule on Server Company.
Note: To synchronise in a private network, use your static IP address, and port number details on which Tally.ERP 9 is running.
'Configuring Data Synchronisation' has been shared with
