Creating TCS Duty Ledger
https://help.tallysolutions.com/docs/te9rel64/Tax_India/tcs/tcs-ledger.htm
You can create a duty ledger for accounting for TCS and also specify the nature of goods.
To create a TCS duty ledger
2. Enter the Name
3. Select Duties and Taxes as the group name in the Under field.
4. Select TCS as the Type of Duty/Tax .
5. Select a Nature of Goods/Contract/License/Lease from the List of Nature of Goods .
6. Press Enter .
7. Press Ctrl + A to save the details.
