https://help.tallysolutions.com/docs/te9rel64/Job_Work/JI_Material_In_Register.htm
Material In Register Report (Job Work In)
Material In Register displays all the material in vouchers recorded to account the receipt of Raw Materials/Components from the Principal Manufacturer.
To view the Material In Registers
Go to Gateway of Tally > Display > Job Work In Reports > Job Work Register > Material In Registers
