You can display the existing Stock Group in Single mode and multiple mode, since it is only display Tally.ERP 9 does not allow you to alter any information in display mode.
To display Single Stock Group
1. Go to Gateway of Tally > Inventory Info. > Stock Groups > Display (under Single Stock Group)
2. Select the Stock Group whose particulars you want to display from the List of Groups . The Stock Group Display screen is displayed as shown.
Buttons |
Short cut Keys |
Description & Use |
C: Category |
CTRL+C |
Allows you to Display a Stock Category. |
I: Items |
CTRL+I |
Allows you to Display a Stock Item. |
U: Units |
CTRL+U |
Allows you to Display a Unit of Measure. |
O: Godown |
CTRL+O |
Allows you to Display a Godown. |
V: Vch Types |
CTRL+V |
Allows you to Display a Voucher Types |
Note: Category and Godown buttons are visible only if you opted for the same in F11: Features .
To display Multiple Stock Groups
1. Go to Gateway of Tally > Inventory Info. > Stock Groups > Display (under Multiple Stock Groups)
2. Select the Stock Group from the List of Groups .
If you select All Items from the List of Groups , all the Groups and sub Groups are displayed.
If you select Grade One from List of Groups , all the sub Groups related to Grade One will be displayed.
Buttons |
Shortcut Keys |
Description & Use |
F4: Parent |
CTRL+F4 |
Allows you to select parent [Stock Group] from List of Group . Selected Stock Group will get displayed. |
C:Category |
CTRL+C |
Allows you to select Category from List of Categories . Selected Stock Category will get displayed. |
I: Items |
CTRL+I |
Allows you to select Stock Group from List of Groups . Selected Stock Group will display related stock items. |
O: Godown |
CTRL+O |
Allows you to select Godowns from List of Godowns . Select Godowns will get displayed. |
Note: Category and Godown buttons are visible only if you have opted for the same in F11: Features.
'Displaying a Stock Group' has been shared with
