https://help.tallysolutions.com/docs/te9rel64/Tax_India/excise-importer/ei-define-tariff-company-level.htm
Defining Tariff Rates at Company Level (Excise for Importer)
Excise tariff rates can be applied at a company level by enabling excise and providing the necessary excise details and duty rate.
Scenario: ABC company is an electronics company dealing with the import of laptops. They import only 12 inch Windows 8 laptops. Let us see how excise tariff can be defined and applied in a scenario like this.
To define tariff  rate at the company level
1. Go to Gateway of Tally > F11: Features > F3: Statutory and Taxation .
2. Set the option Enable Excise to Yes .
3. Set the option Set/alter excise tariff details to Yes in the Excise Details screen.
The Excise Registration Details screen appears as shown below:
4. Enter the excise details and define the duty rate.
The Excise Tariff Details screen appears as shown below:
o Press Enter to save.
5. Press Enter to save the Excise Registration details.
1. Go to the Excise Tariff Details screen (shown above).
2. Enter the new excise Rate .
3. Press Enter . The Tariff Details Applicability screen appears. Enter the Applicable From date.
4. Press Enter to save and return to Excise Registration Details screen.
You can also click L : Details from the Excise Tariff Details screen, enter the Applicable From date and provide the tariff details with revised excise duty.
Creating Duty Ledger
● Create a duty ledger with the Type of Duty as CENVAT and the Duty Head as Countervailing Duty.
Using Defined Duty Rate in a Transaction
On selecting the duty ledger created in a transaction, the duty rate is calculated.
