https://help.tallysolutions.com/docs/te9rel64/Licensing/FAQs_on_Licensing.htm
Licensing - FAQ,  Error Codes, and Error Messages
This topic lists the common queries, error codes, and error messages related to licensing in Tally.ERP 9. Click any of the links for more information.
FAQ
Error Codes and Error Messages
Frequently Asked Questions (FAQ)
1. How do I activate Tally.ERP 9 license?
2. How do I activate a single site account?
3. How do I activate a multi site account?
4. How can I surrender Tally.ERP 9 license from the Control Centre?
5. How to convert or upgrade Tally 6.3/7.2 Hard Lock version to Tally.ERP 9 Soflock version?
6. Is a valid TSS subscription required for filing E-Returns from Tally.ERP9?
7. How do I resolve licensing issues that I may encounter while in Educational Mode?
8. How do I surrender Tally.ERP 9 license from Tally.ERP 9?
9. Can I use more than one Tally.ERP 9 release simultaneously in the same system?
10. Can I use more than one instance of Tally.ERP 9 in my computer?
11. Can multiple users access the same single user license at the same time?
12. Can multiple users access the same multi-user license at the same time?
13. How do I configure license in client system?
14. Why should I unlock license?
15. Where will I get the unlock key?
16. Do I have to be connected to the Internet all the time to use Tally.ERP 9?
17. How do I activate a single-user license?
18. How do I activate multi-user license?
19. What is multi-site account?
20. How can I manage all licenses?
21. Should I have a valid TSS subscription to upgrade?
22. My TSS subscription has expired. How do I upgrade?
23. How do I add Tally.ERP 9 to the exceptions list in Windows XP Firewall?
24. How do I activate and add my Tally.ERP 9 license to an existing Account, and manage all licenses using a single e-mail ID?
25. Do I require administrator rights to perform any licensing operations?
26. What is an Account?
27. What is an Account ID?
28. What is a Site?
29. What is a Site ID?
30. What is Tally.NET ID?
31. What is rental license?
32. What is Tally.ERP 9 Gold license?
33. What is Tally.ERP 9 Silver license?
34. What is a Tally.ERP 9 regular license?
35. What is Educational Mode?
36. Will a Windows standard user require administrator rights to perform any licensing operations?
37. How does Silver Edition (Single User) license work from Release 5.x onwards?
38. What is Tally Gateway Server, and how is it installed?
39. What are the user account control settings in windows 7 for enabling Tally.ERP 9 licensing?
40. How to get the unlock key from Tally Solutions website?
1. Error code 39
2. Error code 52
3. Error code 208
4. Error code 401
5. Error code 402
6. Error code 403
7. Error code 404
8. Error code 405
9. Error code 406
10. Error code 407
11. Error code 408
12. Error code 409
13. Error code 410
14. Error code 411
15. Error code 412
16. Error code 801
17. Error code 802
18. Error code 803
19. Error code 804
20. Error code 805
21. Error code 806
22. Error code 807
23. Error code 808
24. Error code 809
25. Error code 2012
26. Error code 2013
27. Error code 2015
28. Error code 2045
29. Error code 6202
30. Error code 6203
31. Error code 6206
32. Error code 6210
33. Error code 6235
34. Error code 6238
35. Error code 6242
36. Error code 6248
37. Error code 6266
38. Error code 6267
39. Error code 6401
40. Error code 6402
41. Error code 6403
42. Error code 6404
43. Error code 6405
44. Error code 6410
45. Error code 6413
46. Error code 6436
47. Error code 6437
48. Error code 6439
49. Error code 6444
50. Error code 6457
51. Error code 6464
52. Error code 6465
53. Error code 6628
54. Error code 6629
55. Silver License with serial number “XXXXXXXXX” is in use on “system name.” Exit all instances of Tally.ERP 9 and try again .
56. Only one instance of Tally.ERP 9 prior to Release 5.0 can be accessed using the gateway server .
57. License is in use on Gateway - System Name: Port. Connect Gateway – System Name: Port or reconfigure license path on Gateway – System Name: Port and restart .
58. Maximum RDP limit exceeded. Close one or more Tally.ERP 9 instance accessed using RDP and try again .
59. Connect gateway server to internet. License is inactive .
60. Unknown Status 10060 .
61. Only Account Administrator or Site Administrator can perform this activity .
