https://help.tallysolutions.com/docs/te9rel64/Payroll/PF_Admin_Expenses_Ledger.htm
Creating Ledger for PF Admin Expenses (Payroll)
In Tally.ERP 9, you can create a pay head to account for PF Admin expenses in payroll.
To create the PF Admin Expenses ledger
2. Enter the name of the l edger in the Name field.
3. Set the ledger as under Indirect Expenses from the List of Groups .
4. Set Inventory values are affected to No .
5. Select Normal Rounding from the list of Rounding Methods , and type 1 as the rounding Limit.
6. Press Enter to save.
