A POS transaction is recorded using the PoS Invoice Voucher Type created.
To record a POS transaction
1. Go to Gateway of Tally > Accounting Vouchers > F8: Sales to view the Change Voucher Type screen.
2. Select POS Invoice as the Voucher type .
3. Select the Godown , as required.
4. Select the Party's A/c Name , as required.
5. Select the Sales Ledger , as required.
6. Select the Name of Item or create a new stock item.
7. Set the Rate of the item , as required.
8. Select VAT/Tax ledger from the list of Ledger Accounts.
The Accounting Voucher screen appears as shown below:
9. Press Enter to save.
Note: POS invoices can be recorded with different actual and billed quantities by enabling the option Use separate actual and billed quantities in F11 (Features) > F2(Inventory) .
'Recording a POS Invoice' has been shared with
