Multiple devices can be configured for a single company.
To enable multiple devices for a company
1. Go to Gateway of Tally > F11: Features > F3: Statutory .
2. Set Enable VAT? to Yes .
3. Click F12: Configure .
4. Enable the option Set multiple device details?
5. Press Enter .
6. Enable the option Set device details? in Company Operations Alteration screen.
7. Select the Types of Device .
8. Enter the Device Number for each device in the Device Details screen.
9. Press Ctrl+A to save.
'Enabling Multiple Devices (Kenya)' has been shared with
