Excise details such as tariff, non-dutiable classifications, MRP and so on can be configured at company level or as separate masters.
To set excise/tariff details
1. Enter Tariff name .
2. Enter HSN code .
3. Select the Reporting unit of measure .
4. The cursor skips the field Valuation type . To modify it, click F12: Configure and enable the option Allow Modification of Valuation Type .
5. Enter the Rate of duty.
6. Press Enter to save.
To create non-dutiable classifications
1. Go to Gateway of Tally > Inventory Info. > Excise Classification > Create .
2. Enter Tariff name .
3. Enter HSN code .
4. Select the Reporting unit of measure .
5. Select the Type of tariff as Non-Dutiable .
You can record excise details based on the date of applicability for different periods, if required.
To modify valuation types when creating a dutiable tariff
1. Press F12: Configure
2. Enable the option Allow Modification of Valuation Type?
3. Press Ctrl+A to accept.
4. Select the Valuation Type , as required.
1. Press F12: Configure .
2. Enable the option Allow tax based on MRP? .
4. Set the option Calculate Duty on MRP in the Excise classification creation screen.
'Setting Excise Details (Excise for Manufacturer)' has been shared with
