https://help.tallysolutions.com/docs/te9rel64/Banking/view_current_and_final_balance.htm
Viewing Current and Final Balances
Two F12: Configure options are available in the Voucher Creation/Alteration screen to consider post-dated transactions while ascertaining the balances of party ledgers:
โ— Show Bill Final balances : Enabling this option will display the amount that remains due, if any post allocation, in the Bill-wise Details screen.
โ— Show Ledger Final Balances : Enabling this option will display the party ledgerโ€™s balance after including the post-dated transactions for the party ledger, in the Voucher Creation / Alteration screen.
