Error Code 41007: Your license is inactive. Connect to the Internet and try again.
This error occurs when the status of the license is changed to inactive mode (after the threshold limit assigned from back-end) due to non-availability of internet connection on the computer where the gateway server is installed.
For example , if the offline limit for a license is set to 30 days, and the computer is not connected to the Internet for more than 30 days, then the license status changes to inactive mode.
On the computer where the gateway server is installed:
● Go to Control Panel and ensure that your LAN connection is enabled.
● Check if your LAN cable is connected to both your computer and the network wall socket.
After you have resolved the network issue, you can resend the payment instructions to the bank. If this problem persists despite having internet connectivity, contact Tally Solutions.
'Error Code 41007: Your license is inactive. Connect to the Internet and try again' has been shared with
