https://help.tallysolutions.com/docs/te9rel64/Banking/changing_bank_details_during_entry.htm
Can I Change the Bank Details of the Party During Voucher Creation?
Yes, you can change the bank details of the party while creating the voucher. For example , you can change the IFS code.
