Tally.ERP 9 allows you to transfer materials from one Godown to another. The transfer of materials is done using the Transfer Journal Voucher.
To create Stock Journal for Inter - Godown Transfers,
Go to Gateway of Tally > Inventory vouchers > Alt+F7 for Stock Journal and select the class.
Pass the stock transfer entry.
Press Alt+P to print the Stock Transfer Journal Voucher
F12: Print Configuration
While printing Stock Transfer Voucher, set the options Destination Godown on Top of Voucher and Print Godown Address to Yes.
Enabling the option Destination Godown on Top of Voucher will display the Destination Godown name on the top of the voucher instead of printing as separate rows
Enabling the option Print Godown Address will display the godown address as mentioned in the Godown Creation/Alteration screen
More:
Voucher Classes for Stock Journals
'Transfer Journal Voucher' has been shared with
