To view Funds Flow
Go to Gateway of Tally > Display > Cash/Funds Flow > Funds Flow
Press ALT+F2, change period - From: 1-04-2008 to 31-8-2008.
The funds flow statement is displayed as shown.
A Monthly Funds Flow Summary with the movement of working capital for each month is displayed. It shows the Opening and Closing Balances of each month with a column for Funds Flow.
Select a month and press Enter to drill down.
Select F1: Detailed to see the funds flow for the selected month.
'Fund Flow in Tally.ERP' has been shared with
