Inventory information contains the inventory masters. Each master has Create, Display and Alter functions.
These three functions are grouped under:
Single
Multiple
In Single, you can execute the function on one master. In Multiple, you can execute the function on multiple masters.
The Create option is used to create new masters. Any modification to the masters can be done only through the Alter mode.
The Display option is used to view the Master information. Master information cannot be modified in Display mode.
The Alter option allows you to view and make the necessary changes to the master information. This does not allow creation of masters. In Alteration mode, you can delete the master. [Press ALT+D for deletion]
'Functions in Inventory Info. Menu' has been shared with
