Following are the problems faced when job is delegated to a Job Worker
No standard practice to delegate a Job
In real business scenario, the standard procedure of delegating a job -
Raising the Job Work out Order
Material Transfer Out (from the premises of Principal Manufacturer/directly from the supplier of Raw materials to the Job worker)
Accounting the receipt of finished goods
Accounting the Bill from the Job Worker
Payment to the Job Worker
is not followed by all the principal manufacturers. The procedure of delegation of Job varies from organisation to organisation depending on the nature of the Job delegated or type of transaction (depending on the regularity) or relationship with the Job worker.
Monitor & Analysis of Material
Tracking Job Work wise - Raw material to be issued, actual raw material despatched, variance in quantity of raw materials as against the agreed Bill of Material
Tracking quantity of Finished goods to be received, actual receipt and balance
Ageing of Stock (Raw material /semi-finished goods) lying with the Job Worker
Preparing Material Movement Registers
Cost/Profit Tracking: Principal manufacturer can ascertain the cost of manufacture of a job delegated. These statistics can be used to compare and analyse the cost as against cost of manufacture of goods in house or by other Job workers.
Meeting Statutory Requirements
Annexure II - Challan for despatching the inputs, Raw-Materials, semi-finished goods to the Job Worker
Annexure IV - Register for Material tracking (by Principal company if excise applicable)
Following are the problems faced when a Job is received by the Job worker from the Principal Manufacturers
No standard practice for receiving a Job
In real business scenario, the standard procedure of receiving a job -
Receipt of Job Work In Order
Material Transfer In (from the premises of Principal Manufacturer/directly from the supplier of Rawmaterials of Principal Manufcturer)
Accounting Delivery of finished goods
Raising Invoice for billable work/stock
Receipt of Payment from the Principal Manufacturer
is not followed by all the Job workers. The procedure of receiving Job varies from organisation to organisation depending on the nature of the Job or type of transaction (depending on the regularity) or relationship with the Principal Manufacturer.
Monitor & Analysis of Material Received
Tracking Job Work wise - Raw material to be received, actual raw material received, variance in quantity of raw materials as against the agreed Bill of Material
Tracking quantity of Finished goods to be despatched, actual Quantity Delivered and balance
Job Worker Invoice
Tracking of own material consumption by the Job Worker for a job
Billing for the own material consumed for the Job
Cost/Profit Tracking: Job Worker can ascertain the cost of manufacture of a job received. These statistics can be used to compare and analyse the cost/profit of job work carried out for different Principal Manufacturers .
Annexure V - Register for Material tracking (by Job Worker if excise applicable).
'Difficulties in Job Work Process' has been shared with
