To record journal entry to account tax on URD Purchase
2. Click J: Stat Adjustment.
o Select the option VAT in the field Type of duty/tax.
o Select the option Tax on URD Purchase in the field Nature of adjustment.
o Select Additional Details for the type of adjustment selected.
3. Press Enter to return to voucher.
4. Debit a VAT ledger and enter the Rate, Surcharge Rate and Assessable Value in the VAT Details screen.
The VAT ledger must be:
o Grouped under Duties & Taxes.
o Type of duty/tax is set to VAT.
5. Debit a surcharge ledger and enter the rate and assessable value in the VAT Details screen.
The surcharge ledger must be:
6. Credit a ledger created under Current Assets, and enter the value in the Amount field. The completed screen appears as shown below:
7. Press Enter to save.
'Recording Tax on URD Purchase (Haryana)' has been shared with
