                                    To create an expense ledger
Enter the Name.
Select Indirect Expenses as the group name in the Under field.
Set Inventory values are affected to No.
Set the option Is TDS Applicable to Applicable.
Select the Nature of Payment from the List of Nature of Payments.
Press Ctrl + A to save the details.
'Creating Expenses Ledger (TDS)' has been shared with
