https://help.tallysolutions.com/docs/te9rel52/Tax_International/Kenya_VAT/purc_taxable_goods.htm
Purchase of Taxable Goods
Under VAT Act, different VAT rates are defined for taxable goods.
For example:
16% - Computers, Printers, Scanners, etc.
12%-  Diesel oil, Electrical energy, etc.
Purchases
To record transaction of local purchase for items attracting multiple VAT rates
1.     Go to Gateway of Tally > Accounting Vouchers > F9: Purchases.
2.     Enter Supplier Invoice No. and Date.
3.     Select the supplier ledger in Party's A/c Name option.
4.     Select a common purchase ledger in which the option Is VAT Applicable? is set to Applicable, and Set/Alter VAT Details? is set to No without any configuration.
5.     Select the required stock item(s) whose VAT rates are specified either at the stock group or stock item level. Enter Quantity and Rate for each stock item.
6.     Select the common VAT ledger.
7.     Click A: Tax Analysis button to display the Tax Analysis screen.
o      Click F1: Detailed button to view the name of stock item. The Tax Analysis screen in detailed mode appears as shown below:
o      Press Esc to return to purchase invoice
8.     Press Enter.
9.     Press Enter to save.
Purchases with multiple tax rates
While using a common VAT ledger, the tax amount for each item is calculated based on the rate of the respective item as shown below:
The purchase invoice with multiple items attracting different tax rates and commom VAT ledger appears as shown below:
