https://help.tallysolutions.com/docs/te9rel52/Job_Work/Annexure_V.htm
Annexure - V
As per Excise Rules, if the Job Worker is registered under excise he has to maintain Annexure - V to record the Material Movement. In Tally.ERP 9 Annexure - V can be generated when the Excise for Manufacturer feature is enable in F11: Features.
To generate Annexure - V
Go to Gateway of Tally > Display > Job Work In Reports > Job Work Registers > Annexure - V
  • In Select Item screen select the Excise Unit for which the Annexure - V  to be generated
The Annexure - V is displayed as shown
For column description refer the topic Material Movement Register
