To import vouchers execute the following steps:
Go to Gateway of Tally > Import of Data > Vouchers
In the Import of Vouchers screen, enter the required path and filename in the Import File Name (XML) field.
Press Enter to import the Vouchers
Double click on Tally.imp file located in the Tally.ERP 9 folder to view the import log.
'Importing Vouchers' has been shared with
