To record journal voucher for reversal of tax
2. Click J: Stat Adjustment to enable the required options in the Stat Adjustment Details screen.
In the Stat Adjustment Details screen,
1. Select the option VAT in the Type of Duty/Tax field.
2. Select the option Reversal of Input Tax in the Nature of adjustment field.
3. Select the option Manufactured Goods in the Additional Details field.
4. Press Ctrl+A to return to the voucher.
3. Debit expense ledger grouped under Indirect Expenses, and enter the value.
4. Credit the tax ledger created under the group Duties and Taxes.
5. Enter the Rate, Addl. Rate, Assessable Value, Commodity Name and Commodity Code in the VAT Details screen, and press Enter.
6. Press Enter to save.
'Recording Reversal of Tax (Gujarat)' has been shared with
