The POS (Point-of-Sale) feature allows you to create POS Invoices and allows receipt of payments from the customers and print them in the required formats.
The POS Invoicing functionality in Tally.ERP 9 is:
Simple and user friendly
Quick and easy to setup and use
Facilitates faster data entry and calculations
Helps you to calculate sales and sale proceeds
Manages inventory and facilitates bar code scanner operations
Offers a flexible and simple way of querying your inventory and sales information
Helps you to track the movement of items and how much you are spending on them
Tracks and records the date and time of every sale made at the store
Helps faster printing of Invoices
'Features of POS Invoicing' has been shared with
