https://help.tallysolutions.com/docs/te9rel52/Tax_International/Kenya_VAT/purchases_imports_16.htm
Purchases - Imports Taxable
To record a purchase - imports taxable
1.     Go to Gateway of Tally > Accounting Vouchers > F9: Purchase.
2.     Enter Supplier Invoice No. and Date.
3.     Select the Party's A/c Name.
4.     Select the purchase ledger with Imports Taxable as the Nature of transaction.
Note: If purchase common ledger is being used:
■    Click F12: Configure in the invoice and set the option Allow modification of Tax Details for VAT? to Yes.
■    Select Imports Taxable in the VAT Classification Details screen displayed on selecting the common purchase ledger.
5.     Select the stock item imported, enter the Quantity and Rate (in foreign currency).
o      Enter the Rate of Exchange in the Forex Rate of Exchange screen. The amount is automatically displayed in the Amount field.
o      Press Enter.
6.     Select the common VAT ledger.
7.     Click A: Tax Analysis button to display the Tax Analysis screen.
o      Click F1: Detailed button to view the name of stock item. The Tax Analysis screen appears as shown below:
o      Pres Esc to return to purchase invoice screen.
8.     Enter Custom Entry No..
9.     Press Enter to save.
