Saving the Return
https://help.tallysolutions.com/docs/te9rel52/Tax_India/VAT/Goa/GA_Save_Return.htm
Saving the Return
To save the Form III report
1.     Click F6: Save. The message Do you want to Save the Return? appears when the Uncertain Transactions count is zero.
2.     Click Yes to save the return.
The following message appears when the uncertain transactions count is other than zero:
If Form III report has to be saved without solving exceptions, click Yes. To solve the exceptions first and then save it click No.
●      Overwritten on the Form III report saved earlier.
●      Saved as Revised Return.
Re-computing Corrected Return
1.     Generate Form III report for the period for which the return was saved. For example, if the return was saved for the period 1-Apr-2014 to 30-Apr-2014, then view the report for the same period.
2.     The message The return values might have been changed, press F5 to recompute appears with a new section comprising details of:
o      Modified Masters that display the count of purchase and sales ledgers in which tax rates have been modified. Press Enter on Modified Masters to view the details.
o      Modified Vouchers that display the total count of vouchers which are Created, Altered, Cancelled and Deleted.
3.     To include the changes made into the report and recalculate the values, click F5: Recompute. Once the values are recomputed, the section displayed for modified masters and transactions does not appear.
Overwrite Corrected Report
On recomputing the values of modified transactions, Form III report displays two buttons, F6: OverWrite and F7: Save as Revised.
1.     Click F6: OverWrite. The message appears as shown below if uncertain transaction count is not zero:
2.     To overwrite the data with exceptions press Enter. Else solve the exceptions and then overwrite the return. The message appears as shown below if uncertain transaction count is zero:
3.     Press Enter to accept and overwrite the data with modified details.
Save as Revised
To save the recomputed valued as revised return without overwriting the information, click F7: Save as Revised.
1.     Click F7: Save as Revised. The message appears as shown below if uncertain transaction count is not zero:
2.     To save the data comprising of exceptions as revised return press Enter. Else, solve the exceptions and then save it as revised return. The message appears as shown below if uncertain transaction count is zero:
3.     Press Enter to save the data as revised return.
