Scenario: On 30-4-2015, ABC Company paid MAR Tech Park ₹ 5,00,000 as rent.
To create a journal voucher
Go to Gateway of Tally > Accounting Voucher > F7: Journal
Click F2: Date to change the date to 30-4-2015.
Debit the Rent expense ledger.
Enter 500000 in the amount field.
Credit MAR Tech Park. The amount after TDS deduction will appear in the Amount field automatically.
Press Enter.
Enter the Bill-wise Details, as required.
Press Enter.
Credit the TDS tax ledger. The TDS amount will automatically filled in the Amount field.
Press Enter.
Enter Narration, if required.
The Journal voucher appears as shown below:
Press Ctrl + A to save the voucher.
Send your feedback to support@tallysolutions.com |
Tally.ERP 9 Series A Release 5.2/Help Ver 1.4/Feb 2016 |
'Accounting for TDS on Expenses' has been shared with
