https://help.tallysolutions.com/docs/te9rel52/Advanced_Features/Advanced_Accounting_Features/Creating_Budgets_for_Cost_Centres.htm
Creating Budgets for Cost Centres
The purpose of a budget is to control expenditure. You can create multiple budgets in Tally.ERP 9, each for a specific purpose such as for the Bank, for the Head Office, Marketing budgets, Finance budgets, and so on.
  1. In the Cost Centres field in the Budget Creation/Alteration screen, set Yes  to set budgets for cost centres.
  1. In the Cost Centre Budget screen, select a Cost Centre from the List of Cost Centres and enter Cost Centre.
  2. Enter a budget figure in Expenses for the cost centre.
  3. Enter a budget figure in Income for the cost centre.
  4. Enter Closing Balance.
  5. Accept to save.
