Statutory information that is required for a company can be created and managed from here. On enabling a statutory module in F11 (Features) > F3 (Statutory and Taxation), the corresponding options are available in the Statutory Info. menu.
The Statutory Info. menu appears as shown below:
You can create, alter and delete statutory info. as required.
To know more about creating statutory info. click a link below:
'Statutory Info.' has been shared with
