You can display/alter the Godowns in single and multiple modes. It is similar to Displaying/Altering Stock Groups in single and multiple modes. Refer Displaying/Altering Stock Groups for more details.
Go to Gateway of Tally > Inventory Info. > Locations/Godowns > Display (under Single Location/Godown)
Go to Gateway of Tally > Inventory Info. > Locations/Godowns > Display (under Multiple Locations/Godowns)
Go to Gateway of Tally > Inventory Info. > Locations/Godowns > Alter (under Single Location/Godown)
Go to Gateway of Tally > Inventory Info. > Locations/Godowns > Alter (under Multiple Locations/Godowns)
You can delete a Godown/ location via Single Godown/Location Alter by pressing [Alt]+[D]. However, you cannot delete a Godown/location with sub-locations. The lower levels must be deleted first.
'Displaying and Altering a Stock Location or Godown' has been shared with
