Purchase from Lump sum Dealers
https://help.tallysolutions.com/docs/te9rel52/Tax_India/VAT/Haryana/Purchase_from_Lump_sum_Dealers.htm
To record a purchase transaction from lump sum dealer
1.     Go to Gateway of Tally > Accounting Vouchers > F9: Purchases.
2.     Click F12: Configure button.
3.     Set the option Allow modification of Tax Details for VAT? to Yes.
4.     Press Ctrl+A to save and return to invoice.
5.     Enter the Supplier Invoice No. and Date if any.
6.     Select the supplier ledger in Party’s A/c Name field whose Type of Ledger is set as Composition in the ledger level.
7.     Select a purchase ledger in which the option:
●      Is VAT/CST Applicable? is set to Applicable.
●      Set/Alter VAT Details? is enabled.
●      Nature of Transaction is set to Purchase From Composition Dealer.
8.     Select the required stock items. Enter Quantity and Rate for each stock item.
9.     Press Enter to save.
