Updated on: 26-Jun-2019
Valid for Tally.ERP 9 Release 6.5.2 and later
The tax credits of central tax, integrated tax and state tax can be used to set-off the liability of central tax, state tax/UT tax and integrated tax in the order specified under GST.
The order in which tax credit can be offset is given below:
Input Tax Credit |
Set-off against the Liability |
Central tax |
Central tax (set-off complete liability) and then integrated tax (in that order). |
Integrated tax |
Integrated tax (set-off complete liability). Remaining credit, if any, to be utilised to pay central, or state tax/UT tax, in any order and any proportion. |
State tax/UT tax |
State tax/UT tax (set-off complete liability) and then integrated tax (in that order). |
Note: You can also create a journal voucher from Gateway of Tally > Display > Statutory Reports > GST > GSTR-1 or GSTR-2 .
2. Click J : Stat Adjustment .
3. In the Stat Adjustment Details screen, select the options as shown below:
4. Press Enter to save and return to the journal voucher.
5. In the journal voucher, debit and credit the ledgers as per the scenarios mentioned below:
Scenario |
Debit Ledger |
Credit Ledger |
Paying central tax liability, when only central tax credit is available. |
● Debit the central tax ledger ● Enter the amount to the extent of credit available. |
Credit the central tax ledger to set-off the payable amount to the extent of credit available. |
Paying central tax liability, when central tax and integrated tax credits are available. |
● Debit the central tax ledger. ● Enter the amount to the extent of credit available. |
● Credit the central tax ledger, and enter the amount to the extent of credit available. ● If complete central tax liability is not set-off, credit the integrated tax ledger, and enter the amount to the extent of credit available. This is only when the integrated tax credit is not already utilised to pay state tax liability. |
Paying state tax liability, when only state tax credit is available. |
● Debit the state tax ledger. ● Enter the amount to the extent of credit available. |
Credit the state tax ledger to set-off the payable amount to the extent of credit available. |
Paying state tax liability, when state tax and integrated tax credits are available. |
● Credit the state tax ledger, and enter the amount to the extent of credit available. ● If complete state tax liability is not set-off, credit the integrated tax ledger and enter the amount to the extent of credit available. This is only when the integrated tax credit is not already utilised to pay central tax liability. |
Paying integrated tax liability, when only integrated tax credit is available. |
● Debit the integrated tax ledger. ● Enter the amount to the extent of credit available. |
Credit the integrated tax ledger to set-off the payable amount to the extent of credit available. |
Paying integrated tax liability, when integrated tax, central tax and state tax/UT tax credits are available. |
● Credit the integrated tax ledger, and enter the amount to the extent of credit available. ● If complete integrated tax liability is not set-off, credit the central tax ledger and enter the amount to the extent of credit available. ● If complete integrated tax liability is not set-off even after utilising central tax credit, credit the state/UT tax ledger and enter the amount to the extent of credit available. |
Paying cess liability, when only cess credit is available. |
● Debit the cess ledger. ● Enter the amount to the extent of credit available. |
Credit the cess ledger to set-off the payable amount to the extent of credit available. |
'Record Journal Vouchers for Adjustments Against Input Tax Credit (ITC) under GST' has been shared with
