https://help.tallysolutions.com/docs/te9rel65/Payroll/employee_vouchers.htm
Employee Vouchers (Payroll)
You can view the Employee Vouchers from Payroll Reports or Statutory Reports under Display .
1. Go to Gateway of Tally > Display > Payroll Reports > Statutory Reports > Summary.
Or
Go to Gateway of Tally > Display > Statutory Reports > Payroll Reports > Summary.
2. Press Enter on the required Pay Head Type.
3. Press Enter on the required Pay Head.
4. Press Enter on the required Employee Name.
5. Click F1 : Detailed.
The user can drill down to a corresponding Payroll/Payment Vouchers from the above report.
