https://help.tallysolutions.com/docs/te9rel65/Advanced_Features/Advanced_Accounting_Features/Print_Multiple_Addresses_in_Reports.htm
Print Multiple Addresses in Reports
Mailing details specified can be printed in the reports in Tally.ERP 9.
Print reports with Company address
Print Multiple Addresses in Vouchers and Invoices
Print Reports with Company Address
1. Go to Gateway of Tally > Display > Balance Sheet
2. Click P : Print .
3. Click T : Titling .
Enable the option Company Address to Print and select the required Address Types from the list as shown below:
4. Press Enter .
5. Press Ctrl+A .
6. Press Y or Enter to print the report. The Company Address is printed as shown below:
1. From the Receipt Voucher and click P : Print . The Voucher Printing screen appears as shown below:
2. C lick T : Titling .
3. Select the Company Address to Print from the List of Address Types as shown below:
4. Press Enter .
5. Press Ctrl+A .
6. Press Y or Enter to print the report. The voucher printed with the company address appears as shown below:
Note: Similarly, you can print the required address types for other vouchers and invoices.
See Also
Enabling Multi Address
Use Multiple Addresses for Ledger Account
