Viewing Order Position in Stock Summary Report
https://help.tallysolutions.com/docs/te9rel55/Voucher_Entry/Order_Processing/Viewing_Order_Position.htm
Stock Summary report can be viewed by adding columns or
To view the order position in stock summary,
1.    Go to Gateway of Tally > Stock Summary.
2.    Press Alt + F1 (For detailed view).
3.    Press Alt + N > Select Orders & Stock Details.
Orders & Stock Details screen is displayed as shown:
Or
●     In the Stock Summary screen, you can add a new column using Alt + C.
●     Sales Order Reports can be accessed through Alt + F7 or Alt + C of the Stock Summary.
Viewing Purchase or Sales Order Outstanding
To view purchase or sales order outstanding,
Go to Gateway of Tally > Stock Summary > Press F9 > select Purchase or Sales Order.
Note: Inventory Reports and Accounting Reports can also be accessed through ALL other reports by pressing F9 or F10 (Accounting/ Inventory Reports).
