https://help.tallysolutions.com/docs/te9rel55/Maintaining_Company_Data/Company_Info/Gateway_of_Tally.htm
Gateway of Tally
The Gateway of Tally screen has multiple components. The various components are explained in detail below.
After installation, the Gateway of Tally screen appears as shown below:
The various components of Gateway of Tally screen are described below:
Component
Functionality
Horizontal Button Bar
Option to print, e-mail, import, and upload data is available here.
This bar also has options to help you to access help, control centre, and support centre.
Vertical Button Bar
All the button options are displayed here. The buttons vary from screen to screen.
Main Area (Ctrl+M)
Main area is divided into two parts:
In the left-hand side information on the date and the list of companies loaded are displayed.
In the right-hand side the Gateway of Tally menu is displayed.
Information Panel
The Information panel displays the following information:
Product: Displays the Tally.ERP 9 logo. Click the logo to visit the website.
Versions & Updates: Displays details about the current and latest releases and the TDL information. Press Ctrl+Alt+T to display the version and updates information.
License & Subscription: Displays information related to the product license such as Site ID, Account ID, Serial Number and so on. Press Ctrl+Alt+L to display the license and subscription information.
Configuration: Displays statutory details, configuration details such as proxy configuration, data configuration and so on. Press Ctrl+Alt+F to display the configuration information.
Calculator: Mathematical calculation can be done here. Press Ctrl+N to activate the Calculator panel.
Task Bar
System date and time are displayed here.
