Introduction to Advanced Voucher Entry in Tally.ERP 9
https://help.tallysolutions.com/docs/te9rel55/Voucher_Entry/Advanced_Voucher_Entry/Adv_Voucher_Entry_in_Tally.htm
Advanced usage in voucher entry involves using more features of Tally.ERP 9. This would mean entering of data in various pop-up and sub-screens depending on the context and configuration (both F12 and F11) settings.
Click the following links for more:
●     Using Additional Cost of Purchase
●     Using Inventory Allocations
●     Using Tracking Numbers
●     Using Zero Valued Entries
●     Using different Actual and Billed Quantities
●     Using Batchwise details
●     Using Mfg. and expiry dates
●     Using Cost Categories and Cost Centres
●     Using Cost Centre Class
●     Using Multi-currency
