https://help.tallysolutions.com/docs/te9rel55/Tax_India/VAT/Haryana/Tax_on_URD_purchase.htm
Recording Tax on URD Purchase (Haryana)
You can account for tax on purchases from unregistered dealers by creating a journal voucher.
To record journal entry to account tax on URD Purchase
2.    Click J: Stat Adjustment.
o     Select the option VAT in the field Type of duty/tax.
o     Select the option Tax on URD Purchase in the field Nature of adjustment.
o     Select Additional Details for the type of adjustment selected.
3.    Press Enter to return to voucher.
4.    Debit a VAT ledger and enter the Rate, Surcharge Rate and Assessable Value in the VAT Details screen.
5.    Debit a surcharge ledger and enter the rate and assessable value in the VAT Details screen.
6.    Credit a ledger created under Current Assets, and enter the value in the Amount field.  The completed screen appears as shown below:
7.    Press Enter to save.
