Order Outstandings Report (Job Work In)
https://help.tallysolutions.com/docs/te9rel55/Job_Work/JI_Order_Outstandings.htm
Order Outstandings report display the details of all the Job work In orders raised on the Principal Manufacturer which are pending.
To view the Order Outstandings report
●     Go to Gateway of Tally > Display > Job Work In Reports > Order Outstandings.
The Order Outstandings reports are:
●     Orders
●     Components
