https://help.tallysolutions.com/docs/te9rel55/Tax_India/TCS/TCS_Ledger.htm
Creating TCS Duty Ledger
You can create a duty ledger for accounting for TCS and also specify the nature of goods.
To create a TCS duty ledger
1.    Go to Gateway of Tally > Accounts Info. > Ledgers > Create.
2.    Enter the Name
3.    Select Duties and Taxes as the group name in the Under field.
4.    Select TCS as the Type of Duty/Tax.
5.    Select a Nature of Goods/Contract/License/Lease from the List of Nature of Goods.
6.    Press Enter.
7.    Press Ctrl + A to save the details.
