https://help.tallysolutions.com/docs/te9rel55/Voucher_Entry/Inventory_Vouchers/Transfer_Journal_Voucher.htm
Transfer Journal Voucher
Tally.ERP 9 allows you to transfer materials from one Godown to another. The transfer of materials is done using the Transfer Journal Voucher.
To create stock journal for inter - godown transfers,
1.    Go to Gateway of Tally > Inventory vouchers > Alt+F7 for Stock Journal and select the class.
2.    Pass the stock transfer entry.
Printing Stock Transfer Voucher
To print stock transfer vouchers
1.    Press Alt+P to print the Stock Transfer Journal Voucher.
F12: Print Configuration
●     While printing Stock Transfer Voucher, set the options Destination Godown on Top of Voucher and Print Godown Address to Yes.
●     Enabling the option Destination Godown on Top of Voucher will display the Destination Godown name on the top of the voucher instead of printing as separate rows
●     Enabling the option Print Godown Address will display the godown address as mentioned in the Godown Creation/Alteration screen.
