https://help.tallysolutions.com/docs/te9rel55/Advanced_Features/Advanced_Accounting_Features/Creating_Budgets_for_Cost_Centres.htm
Creating Budgets for Cost Centres
The purpose of a budget is to control expenditure. You can create multiple budgets in Tally.ERP 9, each for a specific purposes. If cost centres are enabled for the company, then budgets can be created for cost centres.
To create budgets for cost centres
1.    Go to Gateway of Tally > Accounts Info. > Budgets > Create.
2.    In the Budget Creation screen, enter a Name for your budget.
3.    Enable budgets for groups, and ledgers if required.
4.    Set the option Cost Centres to Yes to view the Cost Centre Budget screen.
5.    Enter a budget figure in Expenses for the cost centre.
6.    Enter a budget figure in Income for the cost centre.
7.    Enter Closing Balance.
The Cost Centre Budget screen appears as shown below:
8.    Press Enter.
9.    Press Enter to save the budgets created.
